Hotsync problem
Forum Smartphones & PDAs : Palmtops - Hotsync problem
Archived from groups: comp.sys.palmtops (More info?)
My boss has the Sprint 650. All was working fine with the synching, but
today we started getting an error. A screen pops up on the desktop which
says that there is a conduit conflict which needs to be resolved through the
Custom option, such as making sure both Contacts or Address Book are not set
to synch. We checked and we can't see any two things that are set to synch
that conflict.
On the log for both the 650 and the Desktop, though, we get a different
message. It says
"An application cancelled synchronization or failed to respond to a Hotsync
notification. Please ensure that you are not currently editing data using
applications such as Palm OS Desktop or Install Tool. (8009)."
We are not doing either during the synch.
What can the problem be?
Sponsored Links
In article <mUWCe.483$0C.296@newsread3.news.pas.earthlink.net>,
v.mcalister@nospam.ejgd.com says...
> that conflict.
I got a similar problem when I tried out the Yahoo! Intellisync software
to synch with the online calendar.
Because the process was designed to replace the Palm Desktop I decided
to revert back. But even after uninstalling, the Yahoo! conduit
remained installed and it required a deal of fiddling to fix it.
I recall a piece of software available to view conduits that are
installed detailed in the discussion on the Palm One support area.
http://tinyurl.com/cb28r
Perhaps you will be able to identify the conduit issue here.
Alternatively you can uninstall the Palm Desktop program, also delete
the HKEY_CURRENT_USER, Software, U.S. Robotics registry entry. Then
reinstall Palm desktop. That should give you a clean install of the
software and conduits.
But my guess would be that you installed, perhaps unwittingly, a program
that took over the conduits leaving the Palm Desktop conduits also
running. Hence the conflict of two conduits attempting to access the
same data.
Andrew
Email address ROT-13 encoded to reduce unsolicited bulk
and commercial Email
naqerjfgrryr@fcnzpbc.arg
Reply to Anonymous
Hi,
Think back to Tue Jul 19, 2005. I know. "Yeah, right!". But seriously, I'm having the exact same Treo 650 problem that you had. Did you find a solution? What did you do to solve the problem. Getting someone from Palm to help me is an exercise in futility! Please help.
Thanks,
Kim
Reply to klm2klm2
Tom's Hardware > Forum > Smartphones & PDAs > Palmtops > Hotsync problem
There are 1031 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
