Crysis problems
Forum Graphic & Displays : Graphics Cards - Crysis problems
just today i have installed a new monitor and have noticed a considerable drop in performance in crysis the montior is bigger 22" from a 17" but i have not increased the resolution before, without sli enabled i used to get on 23-27 fps 1280x1024 very high and get exactly the same on my new monitor but with sli used to get 34-45 fps and now i get the same as if i were not using sli whats going on i have it enabled in ntune and think its working with other games (nothing really pushes the system hard enough though appart from crysis) i have the last drivers installed which i got last night and have not played crysis for a while until today could the driver be doing this?
Sponsored Links
If ALL settings are the same, resolution, driver version, etc... then it makes no sense that your performance would change AT ALL.
However, SLI really doesn't kick in until you reach resolutions higher than 1280x1024 in many cases. I'd suggest you try playing with different resolutions and see what happens.
Depending on your machine, you could be CPU limited too. (You haven't mentioned CPU or Video card models, which is important in a tech situation like yours).
At higher resolutions, SLI can kick in and isn't as limited by the CPU. At low resolutions, CPU is more important and SLI really can't do much of anything.
Since you've got a 22" now, try using the 1680x1050 Resolution if yours uses that as its native (max) resolution. See what happens.
------------------------------ i5-750 @ 2.66Ghz / Gigabyte GA-P55-UD4P / Xigmatek HDT-S1283 (Waiting for Bracket)
2 x MSI GTX 260 Core 216 SLI (655Mhz) / 4GB GSkill DDR3 1600 9-9-9-24 @1.5v
2 x WD Caviar Black 1TB / Thermaltake Armor BWS8003
Win 7 64bit / Antec TPQ-850
Reply to jerreece
i have tried using different reslutions and get small fps drops each time i move up but not much
Reply to Drkailinium
specs Q6600 2x8800 gts 512 4gb
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Crysis problems
There are 780 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
