Hi,
Want to overclock the atom 330 dual core on this board from 1.6 to 2.1Ghz (which is reported as being very easy with stock cooler). Any help much welcome
The board comes with ASRock OC tuner software, but can't find any guides anywhere for this processor. The exact board is
http://www.asrock.com/mb/overview.asp?Model=A330ION
Should run alot better at this speed. Has integrated Nvidia 9 Series ION GPU so not sure how this will be affected, if at all?
Installing 4Gb of DDR3 1066 CL7 RAM (the mobo only support 1066Mhz but ill be installing 1333Mhz) probably Crucial Ballistix, along with a Velociraptor data drive and SSD boot drive.
Will also install a dedicated GPU...comes with a PCI-E 2.0 slot (x16) so wan't the best card that I can get for this setup...but dont want to waste money on extra power if it wont be used. The spec says this PCI slot is 32-bit...? huh ? what do they mean? Am i getting confused with memory addressing (which on all PCI 2.0 seems to be 64 or 128 bit) confused!?
