Hi, I my current system specs are as follows
Motherboard: MSI K9N2 SLi Platinum
Processor: AMD 9600 Quad-Core CPU - @ 2300 (WILL NOT OVERCLOCK)
Memory: 4x 2GB PNY DDR2 @ 800 5-5-5-15 (CANT BE BOTHERED TO OC)
Hard Drive: 3 x 500 GB 32MB Cache RAID0 @ 250Mb/S Both ways, 85MB/S Burst
Video Card: NVIDIA GeForce 260GTX 216 @ 655 / 1050 W/Fixed Shader
PSU: Cooler Master Extreme Power 650Watt (only a 4pin to the motherboard, and only 2 x 6pin PCI)
Computer Case: HAF932
CPU COOLER: Xigmatec S1283
FANS:
Stock 200x200mm Fan in front, and on side
Stock 14Cm Fan on Back
PLANS/MY IDEAS
Can buy a Swiftech 3x120mm Rad+WaterBlock+Pipe for $150AUD
A Pump of some sort
3 x Gentle Typhoon Fans
^^^ all mounted to top of case
A Phenom II X4 955 or A phenom II X6 1090T - dont know which yet
A second GTX 260 216 for SLi (with the OC it should be equal to or better than a 295) if I can find one 2nd hand
A Thermal Take LitePower 700W is available to me for my current CPU as a swap
More HDD's as my current array is a) full b) not backed up
well, the above is probably ALOT of information, if anybody that knows more about computers than me, can have a look, and shoot off some recommendations
it would be great, I will probably have AT MOST 1000AUD available to me, which is probably equivelent to USD800 as parts are more expensive here (even with exchange)
FANS:
PLANS/MY IDEAS
A Pump of some sort
