Hi there everybody
i recently installed a new water cooling system into my computer
my room ambiant temp is about 22 degrees.
originally, i was using a Noctua NH-U12P CPU heatsync with fans,
my idle temps were about 27-29 degrees C and max load at 56C-59C
now i installed a Koolance CPU360 water block with a swiftech 220 rad,
my idle temps are 27-29 and max load is 50-55C. depending on time of day.
is this weird? i've tried re-seating the block twice and i keep getting the same tmeperatures.
my cpu is an i5 750 and i've overclocked to 3.6 Ghz with 1.22 VCore.
i've left the overclock the same on the heatsync fan and with the water cooling so its the same case for both.
