well i completed my build
(e8400(with s1283 HS),p5q pro,4gig gskill,gtx 260 core 216, corsair 750w(overkill, but blackfriday sale),antec 1200(wasonsale)
surprisingly everything worked on the first boot. installed vista, left my comp on for a while, good temps, etc etc.
only thing that bugs me is when i start my comp it says that my harddisk isnt detected for a split second then boots into vista. i dont c why it shows that it isnt detected even though BIOS shows it in SATA1 or w/e
another prob when when i click the start menu and the shutdown red button, it only turns off my monitor and turns off the pc as if it were in sleep mode. when i press the power button it goes straight to the desktop. the only way i can acutally shutdown is if i press the start button and click the '>' arrow and click shutdown
