I think all three can support your dual GTX 295 setup. I suggest you search for each item on NewEgg, and see what those who've bought them have to say.
Mind if I ask what display(s) you're using? You might be paying $1000 for graphics you don't really need.
I've used all major motherboard brands over the last 15 years of building PCs, even Abit and Intel, lol. I find that Asus has given the most reliability, ease of use, manufacture support interms of frequent BIOS updates, FAQs on product webpages, etc...
The previous poster brought up a good point regarding your monitor size and resolution. With two GPUS in each GTX 295, that's gonna have to be a monster-sized screen to fully put to use the power of four GPUs.
As of this moment I still have been using a 2Ghz AMD Turion 64 (would have opted to upgrade if socket did not get obsolete). So I have never used a core 2 processor. It will be my first intel since Pentium 3 I think.
well most of the info is in my "member configuration" under my pic.
I'm just waiting for the damn chip to come out May 31, which sucks, because I enrolled in summer classes and they start June 1.
Once that chip is out, I will get that, the motherboard, an anti-static wrist strap, Nvidia's 3d vision and the Samsung TV.
Hard disk is a Western Digital 1Tb caviar blk. Memory is a 1333 6gb corsair. Would have gotten better, but dont know how to over clock. Researching more on Over clocking after finals....
Using:
http://www.maximumpc.com/article/f [...] its_limits
I have (2) 230mm, (4) 120mm, and (1) 140mm fan, as well as a stock cooler. Hope that could keep the graphics cards cool. Will remove the plastic inside (heard they actaully increase temperature).
Just figured out what that little small looking thing in the corner was...edit.
Forgot to mention the cards I ordered... They will probably ship some to me by May 26... Backordered.
I wait one more week and every online store is sold out... Was hopeing from newegg with a free game, but found one for $504 on provantage.
Message edited by dragonfang18 on 05-06-2009 at 07:08:00 AM
