Here are my specs:
Core i7 920
Asus P6T Delux
G Skill 3x2GB 1333
Sapphire 4870 1GB
Corsair 750
Antec Niine Hundred
So, everything is put together. I've been through the BIOS. I've installed vista. Installed all of the drivers. Been on the computer for hours and hours and no problems at all that I can detect. In my BIOS, it says my CPU is idling around 39 degrees. Here's my problems.
I didn't really change anything at all in the BIOS. I left almost everything on auto. Everything in memory is set to auto. All of the CPU settings are set to auto. I had no idea what to set everything to. Should I go back and change some settings? If so, I have no idea what I'm doing in that department. Any help is much appreciated.
Also, I have no idea how to test and ensure everything is detected and working correctly. I am about to buy a game and test that out. Vista says my TOTAL PHYSICAL MEMORY is 1.99 GB. WHAT THE HELL? I have 6 GB installed. Then, it says total installed physical memory is 6 GB and available physical memory is 4.47 GB. What does this mean?
I guess I should have mentioned that I am not planning on overclocking at the moment. I just want everything running the best they can with my set up.
THANKS!!
Core i7 920
Asus P6T Delux
G Skill 3x2GB 1333
Sapphire 4870 1GB
Corsair 750
Antec Niine Hundred
THANKS!!
