I've connected my 3 fans to the appropriate 3-pin connectors on the motherboard. The temperatures are around 45C so I tried lowering the fan speed somehow to address noise, but no matter what I do the fans run at a constant temperature (1.5k rpm for the CPU fan and 1k rpm for the two case fans).
I enabled Q-fan in BIOS and tried different settings. I ran the Asus Fan Xpert and changed settings. I ran calibration and it shows the same rpms for every % level.
Any ideas?
I've had NO LUCK in using Asus' P6T fan speed controls. Automatic controls for the CPU fan seem to do whatever it is they're programed to do, but changes don't seem to work. And the changes available are CRAP.
In fact, ASUS P6T FAN SPEED CONTROL IS GARBAGE and the company deserves a public flogging for putting such crap into a retail product.
Any ideas?
Yeah well I bought akasa 3-fan controller and installed that. Now I can get my system to be quite quiet... except then it hangs on games so I have to remember to turn the fans up before playing them Oh well
Oh, but it's a good board otherwise.
Odd, mine work just fine. I wonder if it was a bios issue that was addressed later.
I got the board last week. I know they released a bios version just a few days ago to fix a problem with sleep mode, so I'm guessing it's the one prior to that.
Fan Xpert works for me too. I think your fans need to be PWN (?) compliant or something like that. I have the Cooler Master 690 case and it runs all the fans in there, plus my CPU fan. I can change all the speeds, from fixed to variable.
I am not a hardware expert, but maybe this is the issue (lifted from the Asus site)
With Q-fan enabled, fan control is done in hardware, and SpeedFan et al. will only be able to read the fan speed, not control it. In order to enable software fan control, including SpeedFan and Asus' own utilities such as EPU-6 or Fan Xpert, you need to disable Q-fan.
As for PWR_FAN, this output cannot be controlled at all (either by software or Q-fan). You can run a fan off of this header but it will always run full speed.
As far as I can tell, as far as fan control is concerned, the only difference between the P6T and Deluxe is that the Deluxe has three CHA_FAN headers instead of two, so will allow one more fan to be controlled.
