I put all these together, and find that, whenever I turn it on, it gives no signal to the monitor, and does not make a single beep. Strangely, the fans turn on properly, the drives look like they're working (all the right lights come on), and yet... no beep, no signal. Can somebody please help me here?
Solutions that have been suggested in the previous (deleted, for some reason) thread:
- Taking out the MoBo battery for half an hour, then reinserting and restarting (it turned on, turned itself off, then went back to the previously described pattern)
I am currently at my wits end (as I need to do my university work and work on my digital art), so can someone please suggest a solution (preferably not one that ends with me getting a new MoBo and processor, because, being a student, I am skint) and not delete this thread.
Are the expansion cards fully seated?
I had the same problem with my `b` (brothers) system while swapping the installed 7800GTX for my own redundant 8800GTS 640.
The card seemed to be fully seated and the system had exactly the same symptoms; power on, fans twitch, push the start there`s some activity, then nothing.
The soloution was to bend the locking tag on the graphics card (where the locking screw goes) to allow it to seat fully.
Crude and dangerous but it worked.
Check your CPU heatsink. I had a similar issue, on my stock Intel cooler. It has 4 plastic "push pins" They expand out and "lock" under the MB when you push on the connector. Well... one push pin expanded above the MB, so basically one corner of the CPU was raised, keeping the heatsink above the CPU, even though the other 3 pins were push in fully and locked in.
The CPU overheated so fast that it would barely POST. I was getting farther than it sounds for you though.
Do you have onboard graphics? Try skipping the graphics card and sound card. Just go basic MB/CPU/HD/RAM and onboard graphics if you can, see what that shows.
If every thing is all "plugged in" cleanly, I'd suspect MB first, and the PS second, CPU last.
Hrm. Not sure I trust myself to bend the locking tag on the 8800, oozie, I'd best leave that to a pro or something... As to the CPU, checked that, and my heatsink is definitely fine, as is the locking on the CPU itself. Further info: I took out the cards, tried it without both, and exactly the same symptoms, I'm afraid...
