Tom's Hardware > Forum > Motherboards & Memory > Asus > Sata Problems on p5n32-e sli plus
Forum Motherboards & Memory : Asus - Sata Problems on p5n32-e sli plus
Hi
I have an asus p5n32-e sli board.
I really like it and it has worked well untill recently when i sarted have issues with the sata ports
It will all work fine and then it will just drop a sata port and after a restart or two it is back and working fine. This seems to happen from time to time.
Is there anyway to fix this ?
any idea what is causing this ?
Thanks in advance
Z
Sponsored Links
Welcome to the forums!
Tell us about your power supply.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Have you changed in the bios the PCIe frequency from auto/100 to anything else?
Reply to evongugg
Please run hard disk diagnostics.
Reply to evongugg
Here are the specs of the pc if that will help
Asus p5n32-e sli plus
Intel Core2Quad q6600
4gb Corsair ram kit
1x 80gb Seagate sata2 drive
1x 250gb Seagate sata2 drive
1x 1000gb Seagate sata2 drive
1x Lg 22x dvd-writer sata2
Coolermaster silentpro m700 powersupply
Chaintech 8800gt
I have everything at default in the bios.
I have had the harddrive check and they are all fine.
Thanks for the help so far .
Could it be that the board is faulty ?
Reply to Lord Ezekiel
I had the same problem With the sane board and it was a bad SATA port. RMA to ASUS and they replace it with P5N-T Deluxe which is a much better board. http://c4.ac-images.myspacecdn.com [...] 5de5db.jpg
------------------------------ ASUS Striker II Extreme , C2D Q9450 OC 3.4, 8 Gig Memory, EVGA 8800GTX Triple SLI, Thermaltake 1000W PSU, Thermaltake Armor + Case, Acer 24" LCD, Water Cooled, 12 Foot DVI Cable, Vista 64 Bit SP2
Reply to baddad
Thanks for the help.
I will rma it this week.
Thnaks again.
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
