First off, I have recently installed a hyper 212 plus in my non overclocked 1366 rig. According to HW Monitor with the stock intel HSF I was getting idle temps in the mid 40's and under full load prime 95 was reaching 82 celsius. Now with the new HSF I'm getting 34-36 idle and 61 celsius with prime95. Are these temps on par with what most others are reporting? Also I should ask if using something like artic silver 5 would be significantly better than the included cooler master goo that I'm using now.
Next, I have a lower priced lian li case and am wondering if I added this add on fan setup would I get better temps? My case right now has the one front 140mm intake and a small 120mm exhaust at the back with the hyper pushing air towards the exhaust in an east west config. I'm mainly confused on what the best way to get better airflow would be as I also have the option of buying a different top panel that would allow for a fan or even a side panel that would support two fans.
Thanks in advance!
Thanks in advance!
