This is my first build so I could really use some help determining if I made good/compatible/logical choices below! And I intend on running Vista 64-bit (although I've never used 64-bit yet).
*** After reading some other posts just before posting this, I get the impression that I might need a better power supply, and am missing the sound card and ethernet card. And what about heat sink / thermal paste and all that jazz?
Any advice whatsoever is welcome!
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Retail
$189.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
ASUS P5Q SE PLUS LGA 775 Intel P45 ATX Intel Motherboard - Retail
$96.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131347
($81.99 afer mail-in rebate)
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
$54.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184&cm_sp=DailyDeal-_-20-145-184-_-Product
($24.99 after mail-in rebate)
$54.99 - above x2
EVGA 01G-P3-N870-AR GeForce 9600 GT 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
$154.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814130363
Seagate Barracuda 7200.11 ST31000333AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
$119.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148373&cm_sp=DailyDeal-_-22-148-373-_-Product
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
$28.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
Acer X223Wbd Black 22" 5ms Widescreen LCD Monitor 300 cd/m2 2500:1 - Retail
$159.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16824009145&cm_sp=DailyDeal-_-24-009-145-_-Product
$159.99 - above x2
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
$79.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
COOLER MASTER eXtreme RP-500-PCAR 500W ATX12V V2.01 Power Supply - Retail
$44.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817171018
$54.99 - above x2
$159.99 - above x2
