Need help: new computer: direct x
vsdagama
501
Hey,
I just got my new computer last week,
And I installed warcraft 3, it worked fine
Now today I reformatted my hard drives, and installed warcraft 3 again
It says: warcraft 3 was unable to initialize directx. Please ensure you have 8.1 or higher and that your display drivers are current.
Well, when I go to dxdiag, it tells me: Direct-X version: DirectX 10
Thats 8.1 or higher right??
Or is there something wrong with my drivers??
I don't know anything about drivers I just reinstalled my vista and formated my drives, so I don't know what happened
Thanks!!
Wolfshadw
Sounds like the problem is when you re-loaded Vista, you did not reload DirectX9.0L.
DirectX10 is a Vista only API. It's not backwards compatible with XP or applications that require DirectX9 or lower. DirectX9L (for Longhorn, Vista's code name), is a package that allows directx9 compliance in Vista.
-Wolf sends
vsdagama
501
I got it to work (installed the ATI driver from the website, end the directx
Now my sound doesn't work and my itnernet goes uberslow, what to do???
