FANLESS low-power mothoerboard, VGA
I'm looking for a low-power, linux-capable box for around $200.
Required features:
- capable of fanless operation (heat sinks OK, fans are not)
- Modern processor instruction set (Intel, ARM, PPC) for linux ease.
- Able to run *BSD or GNU/Linux
- VGA out to drive an LCD monitor (1280x1024 min. resolution)
- DIMM socket for memory expansion (to 1G or 2G RAM is fine)
- base system can run on 20W power or less (ideally 12W power, 12V at 1A)
- 3-4 USB 2.0 connections
- able to have multiple wired network connections
[PCI expansion is OK, dual ethernet and 802.11b/g/s/n interface is best.]
Nice to have:
- power supply on board, so I can run it on 12VDC @ 1 or 2 A
- able to run Windows XP
- able to expand RAM to 4G if needed
If it helps, here are features I don't need:
- 3d accelerated graphics
- SATA connections, since it will boot from a USB stick or SD/MMC card.)
You can think of this as a netbook for desktop use, or a carputer I can power with solar cells.
I'm aware of the EEE Box, but it is priced at around $300 most places I've looked. I'm looking for something with this cost profile:
$100 motherboard,
$20-$30 for RAM,
$15-$50 for a case if I want one
$5-$15 for the 12VDC power brick if I don't reuse one from USB Hub or a Linksys router
1 answer Last reply
More about fanless power mothoerboard
  1. http://www.yawarra.com.au/hw-alix1.php
    yawarra sells an ALIX 1 system from PC Engines
    However, they don't have the DIMM socket (memory only goes to 512M RAM), and are a little bit out of your price range for your specs.
New Build Power Systems
