I have a problem starting up Asus Maximus Formula II
I just finished putting a comp together i have a asus maximus formula 2 mobo i checked to make sure everything is plugged in properly and when i press the power button the fans spin for a sec and it shuts down. the LCD poster says POWER OFF
I tried pressing the start button on the mobo and samething happens.
any ideas?
(this is the 4th pc i put together never had any issues before this one)
Let me give you guys a little more info... when i turn on the power switch on the PSU the ROG plate lights up and LCD Poster says WELCOME and nothing happens. when i push the power button on the case or the start button on the mobo the fans spin for a sec a few lights come on for a sec and the LCD poster says POWER OFF.
what i tried so far
2 different PSU
unplugging keyboard mouse and monitor
unplugging case fans
removing videocard, audio card, dvd drive & HD
2 different sticks of ram
unplugged the case wires
i currently have the CPU & oem cpu fan plugged in 1 stick of RAM and the 2 power plugs (24 pin & 8 pin) on the mobo and still same thing
i didnt move any jumpers around im not that familliar with mobos to start messing around with that
I made sure all the mobo mounting screws are in and there arent any extras underneath
Im totally stumped the only thing i havent done is try a different CPU but i cant see that making a differance
the mobo is a ASUS MAXIMUS FORMULA II
the cpu is a Intel Core 2 Duo 3Ghz E8400 45nm
the RAM is 1GB OCZ PC2 8500 5-5-5 @ 2.1v Nvidia SLI ready
I tried going to a local Computer shop and the are asking $100 to check it out because i didnt buy it from them i got everything online
any help would be great
thanks
what i tried so far
2 different PSU
thanks
Try booting up the system out of the case on an non-conductive, anti-static surface (a wooden/plastic desk will do). Also, try clearing the CMOS and leave the battery out for a good 10-20 minutes and see if that yields anything.
There may be a slight chance that your current BIOS version doesn't support you CPU. Do you have the C0 or the E0 version?
Ask the community
