Archived from groups: alt.games.the-sims (More info?)
I just took time to download the patch (after all this time... i have no
patience). It took me about two hours, since I'm on a computer that only has
dialup internet. Everything went fine with the download, but now I can't
seem to install the patch. It goes through a couple things, then during
"TSData\Res\Objects\objects.package" installation (or whatever), it quits
and tells me there was an "Error during update installation." I've tried a
couple times, and it keeps doing this. Is there something I can do? Do I
have to redownload the patch?
Pam
Sponsored Links
"Pam" <secretok@gmail.com> wrote in message
news:364uqhF4thebuU1@individual.net...
> has
I had this problem and my only solution was to uninstall the game and
reinstall it from scratch.
Reply to Anonymous
"Gryfallon" <doomdark@hotNOmailSPAM.comTHANKS> wrote in message
news:9GbLd.296$CF5.127@newsfe1-win.ntli.net...
this might be a dumb question, but if i uninstall the game, does it delete
my families?
Reply to Anonymous
I had the same thing happen...but because I'm on adsl it was no biggie to
re download it - and it worked.... but on dial up! I think it is your only
solution :-/
~ jo
http://thesims2.ea.com/mysimpage/m [...] _id=223269
> has
> Pam
Reply to Anonymous
> my families?
Not a dumb question. It gives you the option to retain them or not, I
believe, but don't quote me.
--Cuth
Reply to Anonymous
If you are worried about loosing your families make a copy of the
neighbourhood file they live in. Then, after the re-install delete the
installed neighbourhood and replace it with yours.
MM
"Cuthbert Gurdlestone" <chgurdlestone1154@earthlink.net> wrote in message
news:41FD4AA3.8060205@earthlink.net...
delete
> > my families?
> --Cuth
Reply to Anonymous
> --Cuth
You do get the option during uninstall to keep families and delete them.
-ned
Reply to Anonymous
"Madame Mim" <mad.mim@S.P.A.M.bigpond.net.au> wrote in message
news:E9dLd.141817$K7.97592@news-server.bigpond.net.au...
thanks for the help, everyone! i appreciate it, even though i didn't try
reinstalling the game. i just tried to install the patch again, and it
worked. odd, i didn't do anything different. off to play now!
Reply to Anonymous
If you downloaded and installed a no-blur patch, that will happen.
If you do have the no-blur patch, we can walk you through how to fix
the problem.
BW
Reply to Anonymous
Tom's Hardware > Forum > Games General > Games General Discussions > Problems with the Patch
There are 656 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
