G Guest Guest Dec 11, 2009 #1 If i have windows vista home premuim is there anyway i can upgrade to windows 7 pro using the upgrade version
buwish Splendid Dec 16, 2008 9,854 1 31,460 Dec 11, 2009 #2 Yes. But you'll have to do a custom install (i.e. fresh install), which entails wiping your HDD. Just make sure you back up everything important beforehand. Upvote 0 Downvote
