Hello everyone, I need some advice as I am going to buy some upgrades for my computer soon. Now I should say that these questions might be a little on the stupid side as I don't know a whole lot about compatability of components, I just know how to plug stuff in pretty good. I currently have:
AMD FX-62 dual core 2.8mhz
DFI Lanparty UT nf590 M2RG
4 Gigs of OCZ platinum DDR2-800 PC6400
evga Geforce 8800GTX OC 768mb
BFG tch 650watt psu
Now here is what I want to upgrade:
CPU: AMD Phenom II X4 810 2.6GHz Socket AM3 95W Quad-Core Processor, http://www.newegg.com/Product/Product.aspx?Item=N82E16819103650
Mobo: ASUS M4A79T Deluxe AM3 DDR3 AMD 790FX ATX AMD Motherboard, http://www.newegg.com/Product/Product.aspx?Item=N82E16813131363
Memory: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit, http://www.newegg.com/Product/Product.aspx?Item=N82E16820227320
Now I have a couple of questions, I dont really have a lot money to play with so i hope I can still use the same Power supply that I have, which is this one here: http://www.newegg.com/Product/Product.aspx?Item=N82E16817702003 The Phenom processor that I want to upgrade to seems to use less power than my FX-62 if i am correct, will every thing be safe if I use the same Power supply or will i fry something?
And my other question is, the Phenom has what looks like a slower speed which is 2.6mhz than my current FX-62 which is 2.8mhz, will the Phenom be quite faster because it is using 4 cores or will i not really notice a big difference and a waste of money?
Like I said guys they may be stupid questions but I never took any computer classes in my life, I just basically learn from these forums on the internet. Any help would be appreciated.
BFG tch 650watt psu
