Hello im doing my first build with the antec 900 gaming case i bought for cheap from black friday.
My current PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
It has been in an old computer for awhile and im just going to put it in the new build.
Antec 900 has a bottom mount power supply
a review on the psu says that he needs an extension cable for CPU power or some such(3rd review down)
Where can i get this extension cable?
also it appears that i may need to put the psu upside down to mount it?
anyone have any experience with these two products?
the final product will be this btw
Evga 750I FTW Mobo
4GB DDR2 OCZ 800 ram
2 XFX 8800gt SLI
Q6600 2.4 Quad
OCZ 600W 80 plus power supply with 4 12v rails each at 18A
WDC 500GB sata harddrive-OEM
LG 22X DVD±R DVD Burner with LightScribe Black SATA Model
2 extra 120mm tricool antec fans.
havent decided on a CPU cooler yet(if any)
Windows Vista 32 or 64 bit havent decided on that either
Im thinking of drilling two holes for cable management much like the pictures here
http://www.flickr.com/photos/18177281@N05/sets/72157602923968856/
so i might need more extension cables(2 PCI 6 pins and maybe a sata)
(please comment on the build itself aswell.)
My current PSU
Evga 750I FTW Mobo
2 XFX 8800gt SLI
Q6600 2.4 Quad
