Power Supply
Forum Graphic & Displays : Graphics Cards - Power Supply
Ok i got this new computer it's a compaq, i want to know what video cards could run on my computer with the power supply i have, bestec power supply 250watt, the 12V rail is 14A what card can i run with this power supply computer specs are
Pentium E2160 1.8 GHz
800 MHz front side bus
Socket 775
Memory Installed 2 GB pc 6400
Maximum allowed 4 GB* (2 x 2 GB)
*Actual available memory may be less
Speed supported PC2-6400 MB/sec
Type 240 pin, DDR2 SDRAM
Hard drive
360 GB SATA 3G (3.0 Gb/sec)
7200 rpm
16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
:fou:
Sponsored Links
you're power supply is pretty low. the best you can go for are cards with a 128 bit.
could you also post the name of you're motherboard?
Reply to checkout
Your best bet would be to install either the HD4650 (used 33 watts at load) or the HD4670 (uses 47 watts at load) while the HD4670 might be pushing your power supply it's probably the one i'd pick if it were my system. As with all prebuilt systems when upgrading your graphics download a hardware monitor and check temps with stock system and then keep an eye on them after you upgrade. Both GPUs only require the power provided by the PCIex16 socket. For a HD4670 this is a decent one.
http://www.newegg.com/Product/Prod [...] 6814121274
for a HD4650 i'd go with this one.
http://www.newegg.com/Product/Prod [...] 6814141080
Benchmarks for recent games that include the 4650 and the 4670
http://www.hardwarecanucks.com/for [...] rt-ii.html
Reply to dirtmountain
Motherboard Specifications, MS-7525 (Boston)
http://h10025.www1.hp.com/ewfrf/wc [...] 22&lang=en
also can i really run these cards that were listed with just 12V rail of 14A
aso how about nvidia i am not to much of a fan of ati
Reply to peter2004
- 0 +
umm lets with 14a on the 12v
you could get 8600GT anything above that you need a new psu
unless you go with ati. the 4670 would work good for you. anything above the 8600gt which i would not get if you plan on playing games.
i would go to newegg and get a better psu for around $50 a ocz 500watt and then get a 9600GT if you like nvidia that much.
you really cant get a good nvidia card with that psu.
------------------------------ EVGA 750I FTW |Q9450|Zalman 9700|
DOMINATOR 4GB DDR2 1066|
X-Fi Gamer|
EVGA 9800 GTX 512MB |Antec Twelve|
Reply to killz86
In the mid range cards, ATI is the way to go right now. Why aren't you a fan of ATI? I don't swing either way, I just questions you reasoning. ATI cards have alot more options in the mid range area to.
What do you want a video card for? If you just want a dedicated card and not for games you could get a 4550 from ATI or 9500Gt from nvidia.
with a 250W power supply I would be cautions. Some of those PC you can purchase aftermarket upgrade from a 3rd party. Maybe look into that if you want something for games.
------------------------------ Big Brother Rules with an Iron Fist
Reply to jay2tall
so a 4350 of 4550 would work without killing my computer
Reply to peter2004
- 0 +
4650 or 4670
X-Fi Gamer|
Reply to killz86
arent those a bit high up in power supply requiments
Reply to peter2004
- 0 +
PETER2004: If you want to game with this system the HD4650 is the minimum you should be looking at. At full load it`ll draw just under 3A (Watts=Volts X Amps so 3A X 12V= 36Watts) while the HD4670 draws 4A, leaving your PSU with 10 to spare.
Systems like yours are thr REASON for cards like the 4650/4670.
Reply to coozie7
ok i will give a shot i kust hope the card dosen't mess up my computer thanks
Reply to peter2004
If it messes it up it will be the PSU. What model Compaq is it? if it's not a slimline you could up maybe upgrade.
Reply to jay2tall
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Power Supply
There are 1320 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
