Help selecting Motherboard
Hey,
I am about to buy some new memory: Corsair Dominator 8GB kit DDR3-1600MHz, and I want to overclock my processor so it will be able to run at 1600 Mhz. I will need to buy a new motherboard, becouse my current motherboard only supports DDR2.
My processor is: AMD Phenom II x4 965 BE (3,4Ghz)
So, my question is:
Will my RAM and CPU be a good combination?
What motherboard should I buy?
I am thinking about a budget of €80-100 ($100-125)
The motherboard I have in mind is this one:
ASUS M4A785TD-V EVO
Thanks
2 answers Last reply
More about help selecting motherboard
  1. Corsair Dominator is a great product! I have 6 sticks of 2GB each and they work great. My i-7 920 CPU is overclocked to 3.55 MHz.
    I would suggest that you contact Corsair and ask them your question directly. Here is the link for Corsair: http://www.corsair.com/contact/default.aspx
    After concurrence from Corsair, verify the result with ASUS
    TRUST, BUT VERIFY!
    It is a good idea to check the physical clearances between the CPU cooler and the tops of the Corsair Dominator RAM that have cooling fins attached on top.
  2. Thx for your reply : )
Motherboards Corsair Dominator Processors Overclocking
