X xXTommyXx Distinguished Apr 20, 2010 31 2 18,545 May 23, 2010 #1 As I'm unable to find the optional 2nd fan, I was thinking of replacing the stock fan and fitting two after market fans. Has anyone done this mod? Please reccomend if you have. Thanks.
L logan the huge Distinguished Jan 25, 2010 129 0 18,710 May 24, 2010 #2 Well, if you still want to go with the first option, this is the same fan that comes with the 212+(fan model: A12025-20CB-4BP-C1). http://www.newegg.com/Product/Product.aspx?Item=N82E16835103069
X xXTommyXx Distinguished Apr 20, 2010 31 2 18,545 May 24, 2010 #3 Thanks for the links, however, I did a search for these on Google and I'm unable to find a shop in the UK that sells them.
X xXTommyXx Distinguished Apr 20, 2010 31 2 18,545 May 24, 2010 #4 I found one in Germany!! http://www.aquatuning.co.uk/product_info.php/info/p8990_Cooler-Master-Blade-Master-120-PWM.html Fair price, and correct posting fees.
JofaMang Distinguished Jun 14, 2009 1,939 0 19,960 May 24, 2010 #5 I use 2x 90cfm Cooler Master 120mm LED fans on my 212+ for push/pull. I am quite happy with them.
X xXTommyXx Distinguished Apr 20, 2010 31 2 18,545 May 24, 2010 #6 JofaMang : I use 2x 90cfm Cooler Master 120mm LED fans on my 212+ for push/pull. I am quite happy with them. Too late, I bought one. Thanks for your suggestion though.
