I have an Intel Core 2 Duo e8400. Motherboard is Asus P5Q Pro.
Originally I was having problems with the computer randomly locking up and not posting. I sent the motherboard back to newegg and got a replacement for it.
I just did the install of the new motherboard today and everything boots up fine, but when I checked the CPU temp in the BIOS it was saying it was at 185 degrees F, the motherboard was around 70-80 degrees F. I tried shutting it down and restarting, in case maybe on first boot the thermal compound needed to seal or something, but after booting it was at 145 degrees and climbed to 165 within a minute.
First shouldnt the computer be shutting itself off at 185 degrees?
Second any ideas on why it might be getting that hot? I used Arctic silver 5 http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
It is possible I didnt use enough Artic silver? Here is a picture of the compound on the CPU prior to putting the heatsink on.
I followed the instructions here http://www.arcticsilver.com/pdf/appinstruct/as5/ins_as5_intel_dual_wcap.pdf
