Tom's Hardware > Forum > Homebuilt Systems > New System Build > [New system build] - questions
I'm in the process of putting together / researching parts for a new system build. I built the PC I currently use, but that was several years ago and obviously much has changed since then.
I want a powerful system (goes without saying), but I don't necessarily need the most powerful system on the planet if that makes sense. I'm not much of a gamer, in fact the only game I currently play is Eve-Online, but I'd like the option to be able to play newer games if something catches my eye.
Here's where I'm at so far:
Motherboard: EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard
CPU: Intel Core i7 920 2.66GHz LGA 1366 Quad-Core Processor
GPU: XFX GX260NADBF GeForce GTX 260 Black Edition 896MB
HDD: Seagate Barracuda 7200.11 ST3500320AS 500GB
RAM: OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
CASE: Antec P182 Gun Metal Black
MONITOR: ASUS VW246H Black 24" HDMI
PSU: I have no idea what I need
Some questions I have:
1) The case is a mid tower, do I need a full tower or might I regret not having one in the future?
2) The HDD, I've read some reviews stating a lot of problems with this one, anyone have any other suggestions?
3) The motherboard, $300 for a motherboard seems very expensive. I know it's the latest tech, but could I get away with something cheaper? Any suggestions?
4) The RAM, will I see any benefit from DDR3 1600, or should I go with DDR3 1333, and is this a reliable brand?
5) The monitor, anyone have any experience with this monitor at all? I know ASUS makes good motherboards, but how are there monitors. If you have a better suggestion I ask that it's 24" widescreen and has HDMI and DVI connectors.
6) PSU, I have no idea what wattage, etc. I need in a PSU. Totally clueless on this one.
Thanks for any help/suggestions you may be able to provide.
Message edited by revilot on 12-24-2008 at 08:58:02 PM
Sponsored Links
I'd swap the Seagate for a 640 gig Western Digital drive. More reliable and the price is pretty good. Performance for the drive is good for the price.
You can use a mid tower. Unless you're going to put a lot of stuff in your tower, you don't need a full tower.
As for your motherboard, I actually bought the exact same one for my new rig (still waiting on it to be sent over here, so can't tell you any first hand experience).
http://www.newegg.com/Product/Prod [...] 6813128374
That one is a little cheaper and does not look too bad. The specs say you need 2100+ or 1333 DDR3 memory, so it looks like it does not support 1600 memory.
You might see a small benefit going with 1600 but nothing too significant if you want to opt for 1333 mem. Might be better if you go with the suggestion I made to save a little more money. G.Skill brand is reliable and affordable. Go with that, if you can.
I haven't used ASUS monitors before, but that one looks good for its price. I would recommend performing a Google search on that monitor on reviews to get a good idea on the monitor.
As for a PSU, I recommend this one: http://www.newegg.com/Product/Prod [...] 6817341011
It is a good PSU and it is dirt cheap... well, until the day after Christmas. So if you're going to buy, you need to get on the ball. For $70 dollars, it is awesome.
Reply to Multiplicity
I should have mentioned that at some point I'd probably end up buying a second video card. The PSU you recommended states it would only handle 2x 8800s or lower.
Reply to revilot
http://www.slizone.com/object/slizone_build_psu.html
You can get some more info on some certified PSU's for a couple 260's. The links there brings you to the manufacturer's product page, so you might have to go to NewEgg to see if they offer it at a better price.
There are 1072 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
