Okay, for Christmas, I promised myself a new computer, and the last pieces arrived today (Christmas eve, yay!). So I assembled like a fiend, following every book, step by step. I've built systems before, so I'm not surprised at the current situation, but it's still exceedingly frustrating.
The suspects:
Case: Antec 900
Mobo: Asus P5Q Pro
Proc: Core2 Quad 6600 (With an Artic Cooling Freezer 7 Pro w/ Artic Silver 5)
RAM: 2x 2GB GSkill (slotted in the "yellow" slots)
PSU: 750watt PC Power and Cooling
Video: Sapphire Radeon 4870 x2 (yes, the big honking one. I told you - it's Christmas). Slotted in the upper PCIe slot
HD 1: 500 GB Seagate 7500 RPM SATA (Formatted, blank)
HD 2: 1 TB Western Digital 7500 RPM SATA (Formatted, blank except a few applications I wanted to have ready to go)
Monitor: ASUS 22" DVI
OS: (If I ever get to install it): Windows Vista 64bit Ultimate
After assembling everything I didn't have anything unexpected left over. The connecters that came with the motherboard made plugging the power and reset switches in a breeze (something I usually fight with). Some of the power cables are a tight fit (next time, modular. Rails be damned) I have plugged both a 6-pin and a 6+2pin PCIe power from the PSU into the video card. Without those, the video card spins like mad, but has red lights all over it. So I'm falrly certain the power is in the right place.
On boot up, all fans start as expected, HDDs spin up and DVD burner light comes on. Keyboard and mouse are responsive, and there are no - repeat NO - POST beeps. Can this motherboard even produce them??? I removed the RAM to test and still got no noises...
Anyway, end result, and where I'm stuck is this: The system powers up, doesn't beep, and there is no indication from the monitor that anything is going on. If I switch DVI ports, the monitor acknowledges that it's been removed, but still reports no DVI signal, no VGA signal. I'm fairly certain that if I could get a video signal, I'd see it stopped at the "no bootable devices detected" error message, because pressing Power shuts it down instantly I'm lost guys, and desperately need your help if I'm to have a merry Christmas.
Thanks, and happy holidays to everyone!
Helpless in Houston
The suspects:
Case: Antec 900
Mobo: Asus P5Q Pro
Helpless in Houston
