Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > NEW BUILD!! Did I buy the wrong parts for Gaming computer?
Forum Homebuilt Systems : General Homebuilt - NEW BUILD!! Did I buy the wrong parts for Gaming computer?
Hi, I just bought a lot of stuff and I was wondering if I bought the wrong parts.
Case: Thermaltake Armor+ LCS
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3829132&CatId=1510][/url]
MoBo: EVGA nForce 790i SLI FTW w/ Digital PWM Socket 775
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4197001&CatId=3507][/url]
Processor: Intel Core 2 Quad Q6700 Processor
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3591372][/url]
PSU: Ultra X3 ULT40064 1000-Watt Power Supply - ATX, SATA-Ready, PCI-E Ready, Energy Efficient, Modular
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2700093&CatId=2036][/url]
Video Card: XFX GeForce 9800 GTX + Video Card - 512MB DDR3
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4037153&CatId=1839][/url]
RAM: Corsair Dual Channel 4096MB PC10600 DDR3 1333MHz
[url=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3642209&CatId=3361][/url]
Sponsored Links
Looks fine to me. You went a little apeshit on the PSU. But otherwise everything should work pretty well.
------------------------------ "The surest way to corrupt a youth is to instruct him to hold in higher esteem those who think alike than those who think differently."
Reply to kutark
No looks fine, surprised about you're graphics card though thought you would have went for more power then a GTX+ with the amount you spent on your system already atleaste two and run in sli, or a GTX260, oh well i suppose you can just buy another 9800 in the future and get bang for your buck... not my choice for the case either i would have went for something a bit simplier like an Antec 1200 or even 900 but thats more personal choice...
Reply to OmegaStalker
- 0 +
So it would be wise to invest a bit more money and get two GTX260's instead?
Reply to danlnyc
- 0 +
Haha any other suggestions? I was looking at the Tagan PSU http://www.tagan.com/index.php?opt [...] Itemid=89.
Reply to danlnyc
yeah, probably, but it really depends on your budget and what resolution you are gaming at. SLI'd 260's would run 1680x1050 more than well enough, and could handle 1920x1200 very well also.
Reply to the last resort
- 0 +
Yea, definitely. The Ultra PSUs are for lack of a better word, ****. Lots of people say to avoid them like the plague. I'm one of those people that used that exact line of PSU, just the 650w version, and spent 3 months trying to figure out why i had horrible system stability issues. Come to find out the PSU was delivering bad power. Keep in mind at the time i had a core 2 e6600 dual core, and a 640mb 8800gts. And this supposed 650w PSU wasn't enough to power that.
If you are intending to do SLI or something along those lines, and you reeeaaally want a 1000w PSU, get this: http://www.newegg.com/Product/Prod [...] 6817703003
Personally, i would reccomend: http://www.newegg.com/Product/Prod [...] 6817703019
PC Power and Cooling is a great company, known for quality products, and the 750w will be more than enough for your setup.
Reply to kutark
- 0 +
Aye, will also second the corsair PSU's, they're quality as well.
Reply to kutark
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
