System Heating problems
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - System Heating problems
Hello Guys i have the following specifications now i don't know the power supply i should use so please guide me or tell if there is something i can do.
Intel DG31PR 1333Mhz
intel Core 2 Duo 2.66ghz 6MB E8200
Msi Nvidia 7300GT 256 MB PCI graphics card
2GB kingston DDR2 800 mhz RAM
160 GB SATA
2 DVD Drives.
I use everest software for looking at the system conditions. i noticed that the
core temperatures are about above 40 `C average
GPU temperature about above 50`C average.
Aux temperature about above 100`C average
Motherboard temp about above 55`C average
now tell me r these temperatures high and if they are what should i do.I dont have info about the supply i am using currently.
the temperature increase futher when i play games on PC.
my email is danialkamran@hotmail.com[#ff002a][/#ff002a]
Sponsored Links
A good quality 300W+ PSU would be plenty. Antec Earthwatts, Corsair or Seasonic.
The temps do seem high for idle. Try another program such as Realtemp or Coretemp for the CPU and GPU-Z for the GPU.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
I have the same motherboard purchased retail from Newegg a year ago. My temps at idle are slightly higher than yours. However, when I place my computer next to the balcony door (opened about 6 inches to let cool winter air 8 Celsius some in) and remove the side panel, the temps go down 25 percent. This tells me the temp sensors (located on the motherbaord underneath the CPU and also inside the Nothbridge chip) are working fine. IMO Intel used a cheap heatsink on the Northbridge. I checked Asus motherboards with the G31 chipset and theirs are more robust copper material. You may want to modify your side panel and mount a fan to blow directly to your Northbridge or prop an 80 mm fan on the video card to blow towards the Northgridge. I use PCwizard, real temp, and core temp. The harware monitors within the BIOS matches the temps in PC Wizard so there's no software error reading the temps.
Reply to HundredIslandsBoy
- 0 +
if you haven't seen this link, then read and heed:
http://www.supremelaw.org/systems/ [...] arning.htm
Also, Antec's "SpotCool" is a possibility for you:
http://www.antec.com/Believe_it/product.php?id=ODA=
MRFS
Message edited by MRFS on 03-22-2009 at 06:50:39 PM
Reply to MRFS
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > System Heating problems
There are 1245 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 EChiasson won the Freshman badge
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
