Tom's Hardware > Forum > Graphic & Displays > Nvidia > Help with new graphic card
Forum Graphic & Displays : Nvidia - Help with new graphic card
ok i want to upgrade my system... i currently have a xps 630 with a e8500...4gb and dual 9800gt's i want to upgrade my graphics to something much faster than my dual 9800gt's....my budget is 300-400
Sponsored Links
oo i forgot my motherboard is a nvidia 650i =/..its a dell
Reply to salabarria
why ? arent dual 9800GTs fast enough for u ?
u have a very nice rig,i dont know why u want to upgrade,u have problems ?
Reply to Maziar
well i have a 24in monitor and the resolution is 1900x1200 and i play games like crysis, gta iv, call of duty, basically all the new games out there and i need something more powerful to run the games
Reply to salabarria
Single gtx 280-285 is around that budget. You could pawn off the 9800's and maybe get a gtx 295
Message edited by shiftstealth on 01-19-2009 at 07:15:55 PM
Reply to shiftstealth
well i was thinking about getting the gtx 285 then using one on my 9800gt's as a physics accelerator because i heard you can do that with the new drivers.....and also would a gtx 285 be much better than dual 9800gt's
Reply to salabarria
For that res go for either HD 4870X2 or GTX 295,with my config in sig,i can max out every game out there ;)
Reply to Maziar
but on my motherboard the gtx 295 wont work for my motherboard because my motherboard would bottleneck it
Reply to salabarria
Who said that ?!
Your motherboard has PCI-E 16x slot which supports PCI-E 2.0 cards,PCI-E 2.0 and PCI-E 1.0 dont have alot of difference in performance,so dont worry
Reply to Maziar
There are 930 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
