Crossfire problems
Forum Graphic & Displays : Graphics Cards - Crossfire problems
I have 2 HIS Radeon 4870 1GB vid cards that just don't seem to get along. My mobo is a ASUS P5B Deluxe, which is crossfire ready. I know the mobo runs @16x/4x but even with any video cards in crossfire mode you should see some improvement in performance. WRONG! not me. While playing WoW @ full settings, highest resolution, I get awesome FPS with 1 of these monsters (FPS 100-150 average) BUT, when I add the second my FPS seem to be normal when im standing still and looking around but, once i take 1 step they drop DRAMATICALLY to like 20-26 fps, which is very confusing to me. I really don't think it's the cards because I've swapped both of them out to see if it that was the problem but, I get good FPS with either of them. What I wanna know is why? Why are my fps dropping so damn much, why is there such a decrease in performace when I play WoW. I ran a 3dmark06 bench and I can see that my score was 2k higher than when I had 1 card (before 12106, after 14126), but I just don't understand why it hates WoW. If any of you genius out there has any solution please throw em at me please, I hate to see my second 4870 just sitting there not being used at all. My opinion is the motherboard, but that's just me, I've had this mobo for 2 years now. If you need anymore info just let me know.
Message edited by jmunoz123 on 01-19-2009 at 01:19:38 PM
Sponsored Links
Come on guys, theres gotta be 1 good theory out there, at least one good diagnostician, one good explanation why this is happening. Please help me out, if you need more info on my rig just tell me, ill be happy to help you guys out. Embarrass me for all I care, this is my first build and I'm still in training, I've looked online for an explanation but I can't find one, you guys are my only hope. Please don't let me down.
Reply to jmunoz123
- 0 +
Does WOW support Crossfire? Maybe there is some sort of confliction with crossfire in WOW
Reply to boop334
Make sure to enable Catalyst A.I. in CCC settings. You need it on in order for xfire to work. Also, did you reinstall the drivers after setting up xfire? Not sure what drivers you are using but you should do a full uninstall through add/remove programs, reset your system and then delete all ATI folders, and then install the 8.12 drivers.
You should enable the xfire symbol too when you play just to check. If you don't see it in the upper right corner then it isn't working. If you see it then it is working.
Do you get xfire in other games or is it just WOW? You don't run xfire in different modes BTW. I am not sure what your MOBO does but it will be 4x/4x for example, not 16x/4x. They will bump down to the same speeds.
List your full system specs too. I am suspecting by your low 3DM06 score your CPU is not clocked high and older? AMD CPUs tend to under perform and people are usually caught by surprise at how much they bottleneck GPUs. Also, if you are low on RAM that can give you FPS instability too.
Message edited by SpinachEater on 01-19-2009 at 04:40:27 PM
Reply to SpinachEater
Here are my specs:
Core 2 Duo 1.8 Allendale (2.8Ghz) (old)
4GIG G.skill RAM (new)
Asus P5b deluxe Mobo P965 Chipset (old)
Corsair 750W xfire/sli ready PSU (new)
Maxtor 160G harddrive SATA
Average CD/DVD ROM
2 HIS Radeon HD4870 1G Video Card (2nd not currently installed)
I'm @ work at the moment but, when I get a chance I'll do a full uninstall/install of the drivers, run driver cleaner pro and install the latest drivers and see what happens. I also enable the Asus C.G.I function in the BIOS so the cards can talk to each other.
I'm currently in the process of buying a new CPU and Mobo pretty soon, but I just want to know whats up with the system I have now.
I know my CPU is holding back the performance of the cards as well as the mobo, but that being said there still shouldn't be such a severe decrease in performance when I play WoW. I have Crysis Warhead and FarCry 2 im gonna install when I get home and see if it theres a drop in performance on those games. If that's the case then its most likely has to be driver problems, outdated CPU and mobo or maybe something else I can't think of. I currently have the latest BIOS installed also, not sure if that can be a problem too.
If you have anymore theories from the info I just added please shoot em at me. Oh and I also have the latest ATI drivers currently installed too.
Reply to jmunoz123
I'll tell you what the problem is, you're using a 16x 4x configuration. While one card gets the full 16 lanes the second card is being severly limited by only have 4 lanes available to it. Having an uneven configuration like that just doesn't sit well with crossfire. For example, even though a 4x PCI-E 2.0 slot provides the same bandwidth as an 8x PCI-E 1.0 slot, using two 8x PCI-E 1.0 slots will give you better crossfire performance than using a 16x and 4x PCI-E 2.0 slots. Check out this article on Legion Hardware done using 4850s
http://www.legionhardware.com/document.php?id=761
Also consider that some games just don't like crossfire too much, and using a 16x 4x PCI-E 1.0 crossfire setup sure doesn't help any.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
ok so then the major problem is just outdated hardware, im just glad its not my cards cuz i hate going through the RMA process. Thanks for the help you all, very much appreciated.
Reply to jmunoz123
Ah, I am wrong. Your board does run in 16x/4x. Here is another article where they say the 4x creates a bottleneck.
http://www.anandtech.com/video/sho [...] i=2837&p=2
However, in our CrossFire result the P965 trails the 975X by close to 13% which is significant. We looked over the results and found in the SM2.0 tests the P965 solution was about 3% behind the 975X scores, the CPU score favored the P965, but the HDR/SM3.0 tests showed a 12% difference on average. Since the HDR/SM3.0 tests heavily stress both the CPU and graphics bus we figured the x4 PCI Express lane limitation was causing the bottleneck.
You were right!
I see now, but beside that fact, I did some snooping around the web and found out that WoW doesn't support crossfire that well because of the new patches and the SHADER engine. There are no fixes as of yet until ati comes out with a new catalyst driver but ppl have been tweaking with the game found a way around the problem.
I'm gonna try it out later on when I get home today. Surprisingly enough others have been having the same problem I've been having with the same video cards and the 38xx series. Severe stuttering, massive decrease in FPS, and when they turn off crossfire, everything works fine.
I installed Crysis, and Oblivion the other day and saw no problems running them with crossfire. I ran Crysis Warhead on max settings with 1280x1024 res, and I got around 30-40 FPS on average,lowest 24. Oblivion ran awesome with max settings and max resolution 1680x1050 I think it was. So yea its been WoW this whole time, thats a load off my shoulders. You guys have been great and very helpful, Ill be back with more questions and concerns, you can count on it.
Message edited by jmunoz123 on 01-20-2009 at 02:29:48 PM
Reply to jmunoz123
There ya go, a little google never hurts.
I'm thinking about buying a p45 board for an upgrade, its reliable and very affordable. I WISH i had the money to get me a good x38 or x48 for the dual PCI 2.0 @16x but, its just a little above my pay grade with bills and all. So here tell me what you guys think of this board, if you have anymore suggestions let me know.
[url][http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358][/url]
Along with a C2D Wolfdale 8400 CPU.
These 2 things are all i really need for now. Everything else is up to date, new PSU, new vid cards, new RAM, only 2 things holding me back from my awesome to decent rig.
Message edited by jmunoz123 on 01-20-2009 at 05:50:45 PM
Reply to jmunoz123
Great board. I have an x38 board from Gigabyte and it works perfectly. I even had to go through their RMA process not too long ago for a bad BIOS flash and they were really easy to deal with. 3 year warranty covered everything. I had it back within 3 weeks.
Can you find the extra $20 to get a Q6600? They are great CPUs that OC very nicely.
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Crossfire problems
There are 715 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
