Solved
Phenom Ii x4 965 BE and HAF 922 cooler help!!
  • Heatsinks
  • Cooling
  • Phenom
  • Overclocking
May 28, 2010 6:14:32 AM
I have a Crosshair III,Phenom II 965 and HAF 922.
The stock cooler sucks to the core so I'm gonna buy a new one.
please suggest me the best air coolers. I want "THE BEST" one so i can overclock at least above or to 4Ghz and still have good temperatures.
More about : phenom 965 haf 922 cooler
May 28, 2010 8:29:25 AM
Tuniq Tower 120 Extreme
m
l
a c 296 K Overclocking
May 28, 2010 3:44:31 PM
Hi.
U can see here the best CPU coolers.
With any one of those u can get the 4GHz and good temps.
m
l
May 28, 2010 7:33:24 PM
And one more thing I've heard people saying that overclocking kills life,this and that. Is that true..??
I mean if I overclock my CPU and still the CPU is running at good temperatures,will it kill some life or something??
and can we cooler master V8 compared to these??
As in my country cooler master gives good support and is easily available or Thermaltake another brand.
But if they are not good I'll import one cooler like TherMax Eclipse II.
m
l
Best solution
May 28, 2010 7:49:12 PM
1- If u do a bad OC is true that u kill ur CPU. Now if u are a enthusiast(I think that u are for ur nick), trust me, that 965 will no have more that 1 or 2 years in ur hands.
2- The CPU are designed to support high temps (62C in AMD), but u can go with 65 without problems and if u don't rise the temp above 70C ur CPU will be fine.
3- The V8 is a crap for the money, currently I have a Hyper 212+ and I can get 4GHz without problems.
4- Thermaltake have a good coolers and is good manufacturer too.
May 28, 2010 8:12:52 PM
Ok then, I'll either go with Thermaltake Frio or ask my nearest dealer to import one TherMax Eclipse II.
And Thanks a lot.
You've saved me again.
Hope I'm not irritating you. :D
m
l
May 28, 2010 8:19:03 PM
Sorry i forgot to mention,at full load and at 25-27C room temp.
m
l
May 28, 2010 8:49:37 PM
Don't worry man, isn't irritating we are here to help the people and find help too.
m
l
June 13, 2010 2:38:58 PM
Bought a Hyper 212+.
Temperatures
31C - cool n quiet disabled(idle)
53C - prime95 Torture Test!!(used to be 63 C with stock cooler)
m
l
June 13, 2010 5:01:27 PM
Good, if u need help with the installation process, check the link of mi sig and don't forget solve the thread.
m
l
June 13, 2010 5:15:45 PM
Best answer selected by amdenthusiast.
m
l
June 15, 2010 7:19:07 PM
amdenthusiast said:
Bought a Hyper 212+.Will not be overclocking soon.
Temperatures
32 C - cool n quiet enabled(idle)
40 C - cool n quiet disabled(idle)
53 C - prime95 Torture Test!!(used to be 63 C with stock cooler)
Thanks again.....
Sounds about right. I get those temps in prime 95. I have a sunbeam ccf 120mm which is similar to your 212. Are you in california by the way? Those temps are exactly what I get.
m
l
June 16, 2010 6:37:16 PM
I found out that these benchmarks are wrong.I've corrected them above also.
These are the correct ones
31 C - cool n quiet disabled(idle)
53C - prime95 Torture Test!!(used to be 63C with stock cooler)
These are with the paste given to me along with the cooler and I suppose it's not a good one as it wasn't spreading easily and was not that thin. Tomorrow I'll be buying a good thermal compound and I hope it will make a difference of about 3-4C
I live in India :)
m
l
June 20, 2010 10:35:19 AM
Ok the final temperatures
32 C (Idle/Browsing) (Air Conditioner ON)
38 C (Idle/Browsing) (Air Conditioner OFF)
46 C (Prime 95 Torture Test) (Air Conditoner ON)
51 C (Prime 95 Torture Test) (Air Conditioner OFF)
Like SAINT19 said I can easily get 4Ghz!!
m
l
June 21, 2010 2:36:50 AM
Nice, I think that u can try to go for the 4.2GHz.
m
l
