Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Graphics card installation problems
Forum Graphic & Displays : Graphics Cards - Graphics card installation problems
Hello,
I have a DELL Vostro 200 and am installing my first PCI-E graphics card:
ASUS Nvidia Geforce 7600 GT. 256mb
My monitor is a VGA monitor and I am using a DVI-D to VGA Monitor Converter to connect the monitor cable to the graphics card. I am uncertain if this is the right converter.
When I switch the PC on, I have a complete blank screen on my monitor. It doesn't power up to show anything.
I know the PC boots up normally, I can even click to login (although blind) so it all works except I can't see anything.
The PC definitely detects the graphics card as I am currently using the integrated graphics card to write this and on bootup I get a message telling me that I should be using the new graphics card.
Please help with advice if you can.
Sponsored Links
If you can return it you should get a Radeon 4670 or 9600GT which are way better.
In the BIOS you should disable the onboard GFX and set primary as PCIe. Is you PSU powerful enough to handle the 7600GT?
Reply to sabot00
Hi there, thanks for replying.
It's not brand new so I can't return it, it should suit my needs anyway.
I had changed the BIOS already but it didn't help.
I'm uncertain about the PSU power, I'll check it out.
Reply to nizahe
Have got a 300 Watt power supply, 400 Watts is recommended but I doubt it's the PSU stopping from me even seeing a bootup screen.
Reply to nizahe
Do you have two DVI ports? Did you try the other one?
Reply to SpinachEater
Take it out and blow in the pci-e slot.
Reply to shiftstealth
There are 1060 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
