HEY GUYS
this is my first true build, im sort of a neophyte, but i am extremely enthusiastic about building my first comp today on christmas, i finally got my hands on all the parts, which i picked out, and have been precariously waiting on for months now, and im having some troubles. no one in my family is any good with computers, so im turning to you guys. I have a feeling that im missing something exceedingly simple and i'll probally feel pretty stupid when yall finally bring it to my realization nevertheless, any help is much appreciated
to my understanding, i first need to plug my monitor into my mobo inorder to install the mobo drivers and disable the integrated graphic drivers before installing the video card and running the monitor through that and eventually installing its respective drivers.. the problem w/ this is that on my P5Q SE motherboard, there seems to be only audio, mouse, keyboard, and usb jacks.. nothing for a monitor ): so ive installed the gpu and plugged the monitor into the gpu. so i boot up, and all the fans are running great, (including the gpu's) led lights are blaring, everything sounds right, and well other than the lack of picture, everything seems to be spot on. IS there anything i need to do inorder to get my monitor to run w/ my gpu? do they expect me to install all of the drivers blindly, or is there something im missing?
the other problem is that my apevia X-discovery, which came w/ a power supply, has all of those little cables for the system panel connector but it seems to lack the tiny 4-pin connector for the system warning speaker and this thing seems to be pretty important, since its morse-code-like beeps are the only way for my precious comp to communicate its problems to me. will any 4-pin from the psu work? though that doesn't seem right, hence the user manual made it out like the cable would be fed from the chassis like the rest of the cables that plug into the panel connector.
specs:
-pentium 4, 3.00GHz (prescott)
-p5q SE mobo
-4x 2GB Ballistix ram (*8GB total)
-BFG 9600GT factory OC
-Apevia X-discovery w/ blue leds
-umm if you need to know anything else just ask
-p.s. the monitor has one of those little blue connectors, so i used an adapter to convert it to the wider white plug on the gpu.. don't know if that means anything.
please help me figure this out, ive been looking forword to my first build for months, planning and whatnot, done all my research and now ive finally put it into action but ive hit a roughpatch, please help me get through it
Thanks for reading,
-Kyle
specs:
-p5q SE mobo
Thanks for reading,
-Kyle
