Need a little help...
Hi,
OK, so I recently built up a sweet new system, but it keeps freezing and crashing. The "solutions centre" (yes I'm running Vista :s) isn't overly helpful.
I like to think that I know a bit, but this is beyond me.
This has been happening more often when I am playing games. As you can imagine, this is particularly frustrating.
It does happen when just browsing on the net, but not as often.
I don't think that its down to head, as I have a huge Zalman sink on my CPU, and have Everest (machine monitoring tool) running. It says my GPU hasn't gone above 49C.
The spec is as follows:
Intel Quad Core 2 3.0GHz (Q9650)
Corsair Memory 4GB (2X2GB KIT) DDR3 1600MHZ
2 x EVGA GeForce GTX 260 896MB DDR3
ASUS Striker II Extreme MoBo
CoolerMaster 700W PSU
3 x Western Digital 150GB VelociRaptor (RAID 5)
I don't think that the power is an issue (although I do now think that the PSU is a little bit under powered), as I have tested by removing one of the graphics cards.
Please help, as this is driving me mad!!!
All I wanna do is play some games!
Thanks
Cyn
3 answers Last reply
More about need help
  1. I've been seeing a bunch of reported bad RAM from Corsair lately most of which is 1066 kits. Suggest you first start with running Memtest86+ to see if you got stuck with a bad set. Seen one guy report he tested his and ended up going thru 4 different sets before getting a working set. You can download Memtest86+ from here:
    http://www.memtest.org/
  2. Good suggestion. That's where I'd start as well.
  3. I've just tried to run Memtest86+ (several times), and each time, the machine crashes. I can now safely state that its the RAM!
    Thanks for your help guys!
Homebuilt Systems
