I want to connect 20 Hard drive in one system
hello,
want to make data server , so i want 10-15 sata connector on motherboard.
any motherboard is available in market ? this is having 10-15 on board sata connectors ?
3 answers Last reply
More about connect hard drive system
  1. You might be pushing it to get more then 8, with 2 TB drives now available, should be enough. You could use pci/pciE cards with 4 sata on them to get more.
  2. I know that some of the Gigabyte and eVGA motherboards have 10 SATA ports on board.
  3. Using Newegg's Powersearch, there are only 5 intel mobos that have 8 3gb/s sata ports.
    View this link http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=280&Description=&Type=&N=2010200280&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=2968%3A19456&PropertyCodeValue=2968%3A22574&PropertyCodeValue=2968%3A28050&PropertyCodeValue=2968%3A27102&PropertyCodeValue=7968%3A56407&PropertyCodeValue=7968%3A57760&PropertyCodeValue=7968%3A49719&PropertyCodeValue=7968%3A55465
    There is only one AMD mobo that has 8 3gb/s, which is MSI 790FX-GD70 ATX AMD Motherboard.
    The first question you should consider is why on earth would you need 20 HD's? Unless you are building a server for a company with 500+ employees this is extreme overkill.
SATA Connection Hard Drives Motherboards Storage Product
