Tom's Hardware > Forum > Motherboards & Memory > Memory > Need recommendation for my new system
Forum Motherboards & Memory : Memory - Need recommendation for my new system
I've built systems before, but it has been awhile since my last and was hoping I could get some advice since hardware standards have changed so much in the last few years.
I'm putting together and AMD gaming system based on the new MSI 790FX-GD70 board
http://us.msi.com/product/p_sp...l [...] 0&class=mb
However I an a little confused on the ram standards used today when it comes to specific chipsets. The mobo is compatible with 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
So I found a RAM kit I wanted from G SKILL here
http://www.newegg.com/Product/...?Item=N82E16820231225
The kit seems to be the correct voltage, timing etc but say's it's for the I7 series of CPU's. Does this mean it's incompatible with ATI chipsets/cpu's?
If it's not compatible could someone point me to a good 4gb G Skill DDR3 set that is compatible with my selected mobo? I've found a couple that MSI recommends but they are fairly expensive (Corsair) compared to G Skills prices.
Thanks for any advice,
Tony
Sponsored Links
The mobo you are going for only supports dual channel ddr3 ram. Correct me if I'm wrong but the only cpu's around that support triple channel are the i7's.
http://www.newegg.com/Product/Prod [...] 6820231189
This is something more of what you need I believe.
Hope this helps
Matt
Reply to amdforlife
There are 430 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
