Tom's Hardware > Forum > Homebuilt Systems > New System Build > Can I use a 4pin 12volt in an 8pin slot?
Forum Homebuilt Systems : New System Build - Can I use a 4pin 12volt in an 8pin slot?
I'm putting together a new system and I bought this motherboard
and this power supply
I was surprised to find the mobo has an 8pin 12volt socket. My power supply only has one 4pin connector.
the mobo manual says "Use of a power supply providing a 2x4 12volt power connector is recommended by the CPU manufacturer when using an Intel Extremem Edition CPU (130W)"
Now the CPU I got only needs 65W, so I don't believe I have an extreme edition.
I've seen various opinions on this from other websites and reviews. I have just the one 4pin plugged in and the computer runs fine with two exceptions.
1) Windows 32 bit XP mce only recognizes 2.5 of the 4gb of ram. I know that b/c its 32bit it won't recognized the full 4gb, but another system I build recognized 3.5 of the 4.
2) when I use cpuid it shows the cpu running at 1999mHz.
So after this long post, my questions are;
Is it a bad idea to only use the 4pin 12volt connector? Should I buy a new psu?
Also I do not plan on overclocking anything.
Sponsored Links
Your fine. Speedstep throttles your CPU @ idle, it will go full throttle when it needs to.
I like to disable speedstep in the bios cause it feels a little laggy to me.
You video card is taking away from your system ram since 32bit only can address 4g of memory.
Reply to roadrunner197069
So I don't need to worry about overloading that 12volt rail.
Thanks.
Reply to localrob2
Thanks for such fast responses.
Reply to localrob2
There are 499 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
