I hope there aren't any previous threads to what is probably a simple mistake of mine in all of this >_>
I've had my i5 for a while and decided to see if I could push it a little bit (first time overclocking). I upped the bclk from 133 to 160, multi 20x, 3.20ghz easily the first time but it ran a bit hot. Reverted to stock settings, shut down, and left for a while.
I came back and set it to bclk to 150, same multi, to 3.00ghz. It's still fine. But I know that people easily pushed it to 3.4 on stock voltages so I decided to send it back up to 160 and this time remembered to disable turbo boost, eist, c1e, lower the QPI, etc. This time it won't even boot.
I checked the stock voltages and thought they were a bit high, vcore 1.2675v I think. But I went hunting around and other people have overclock's to 3.40ghz, same multiplier, bclk 170 with the same or an even lower vcore.
I tried someone else's settings as this
multi 20x
bclk 160
adjusted ram speed
vcore= 1.26875v
vtt= 1.210v
PCH=1.050v
PLL= 1.80v
Still a no go, it doesn't boot and the same message comes up saying it won't because of overclocking and changes in voltage. Setting a base clock of 150 is still fine with no other changes but I'd still like to try and hit 160. Oh, and my cooler is fine, it's an Arctic Cooling Freezer Pro rev. 2. It gets the temps down a little better than the stock. I just can't understand how it's saying the voltages aren't working!
Thanks for any replies
multi 20x
bclk 160
adjusted ram speed
vcore= 1.26875v
vtt= 1.210v
PCH=1.050v
PLL= 1.80v
