http://www.gigabyte.com.tw/Support/Motherb...?ProductID=2739
http://www.newegg.com/Product/Product.aspx...N82E16820211188
http://www.newegg.com/Product/Product.aspx...N82E16814125089
I don't have a link for the processor, don't really need one though.
Anyways, my old system is a 4000+ socket 920, 1 gig of ram, and 8600 GT. My new system is a Phenom 9600 Black edition with the B2 stepping, 4 Gigs of A-data ram, GA-MA770-S3 mobo, and Gigabyte GV-NX88T256HV1 GeForce 8800 GT 256MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card. My old system plays World of Warcraft much smoother/higher frame rate. Anyways, I have checked temps, tried intsalling the drivers for the north and south bridge from gigabyte's site and right from ATI thinking maybe it was a driver issue. I've tried Windows XP and Vista on the new Phenom system. In Vista it's really horrible. I get about half the framerate that I do in Xp which made me think more of a driver issue. I've tried using the 32 bit version of xp and it's still slower than my old system. I've even tried turning down all the settings in the game too. I've noticed that the northbridge is really hot. Like burn your fingers if you touch the heatsink hot. Looking at the 82 degrees celcius on one of the temps from HWmonitor is what made me touch the heatsinks. Any hints on troubleshooting this guys? Any free games or something I can download to test it out? I don't really own any other games to do some tests and I'm not paying for the 3dmark program. Hope I provided enough info for someone to help me/point me in the right direction.
I was kind of thinking something is wrong with the northbridge. Anyone have any theorys that can track down the problem? I'm on tight budget and not sure if I should call Gigabyte's tech support.
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model GA-MA770-S3 (0x294 - 0x5265A2B0)
Processor 1 (ID = 0)
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Phenom X4 9600 Black Edition
Codename Agena
Specification AMD Phenom™ 9600 Quad-Core Processor
Package Socket AM2+ (940)
CPUID F.2.2
Extended CPUID 10.2
Brand ID 11
Core Stepping DR-B2
Technology 65 nm
Core Speed 2310.4 MHz (11.5 x 200.9 MHz)
HT Link speed 1808.1 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
L3 cache 2 MBytes, 32-way set associative, 64-byte line size
Voltage sensor 0 1.28 Volts [0x50] (CPU VCORE)
Voltage sensor 1 1.94 Volts [0x79] (VIN1)
Voltage sensor 2 3.23 Volts [0xCA] (+3.3V)
Voltage sensor 3 5.00 Volts [0xBA] (+5V)
Voltage sensor 4 12.22 Volts [0xBF] (+12V)
Voltage sensor 5 -12.48 Volts [0xC3] (-12V)
Voltage sensor 8 3.26 Volts [0xCC] (VBAT)
Temperature sensor 0 36°C (96°F) [0x24] (TMPIN0)
Temperature sensor 1 39°C (102°F) [0x27] (TMPIN1)
Temperature sensor 2 82°C (179°F) [0x52] (TMPIN2)
Fan sensor 0 2576 RPM [0x106] (FANIN0)
Fan sensor 1 1099 RPM [0x266] (FANIN1)
Fan sensor 2 1683 RPM [0x191] (FANIN2)
Codename Agena
CPUID F.2.2
Extended CPUID 10.2
Brand ID 11
Core Stepping DR-B2
Technology 65 nm
