What can also be guesstimated. If the PSU is rated 80Plus then simply multiply the Kill-A-Watt reading by 80%. If the power supply is generic or from 2 years ago (or more) then multiply by 65% - 70% since that was roughly before the 80Plus standard became wide spread.
The difference between the outlet measured AC wattage and the estimated DC wattage is wasted in the form of heat.
------------------------------Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
