Power Supply Tester
  • Power Supplies
  • Light
  • Components
Last response: in Components
March 25, 2009 8:29:19 PM
Hi Guys,
Really quick question... Bought a PSU tester to check some older PSU's and have a question.
I tested it on my OCZ EliteXStream and my cheaper winpower 600w one... and when i plug the 20/24 pin connector in all the lights show except the -5v
It has +3.3v,-12,PG,+5VSB,+12,-5V,+5V
On both PSU's everything lights up as normal except the -5v...
When I plug it into a much older 350w eagle PSU, the only difference is that it doens't have a 6pin PCIE and HAS a P4 Connector, and ALL the lights come on including -5v.
Should I be worried? or is this normal not to have a -5v on new PSU's?
Alex.
More about : power supply tester
a b ) Power supply
March 25, 2009 9:55:21 PM
No modern MB do not use -5/-12 V
a b ) Power supply
March 25, 2009 9:55:35 PM
Yes, it's normal.
