My brother in law bought a new computer, and he asked me my opinion on a temperature problem he is having.
When he starts his computer and start RealTemp, he has a temperature of 52-54 C then he runs the test and in less then 20sec his temp goes up to 90C.
Here's his spec:
CPU: Intel quad core Q9550,
Video card: 2 X Palit Crossfire 4870 512 mb,
HSF: Zalman 9700NT,
Motherboard: Gigabyte X48-DQ6,
Memory: Kingston HyperX4Gig 1066Mhz DDR2,
Harddrive: Seagate 1TB,
Case: Anctec Nine Hundred tower,
Powersupply: Antec 850W power supply
I told him to bring it back to the store and so he did, after 11days, they told him that it was normal!!! (yeah right!)
The room temp is always around 20-22C
He tried without the sidewindow and with a fan blowing in and said it didn't change a thing (with the ventilation his case has it shouldn't matter either)
I told him to check if his Heatsink was well seated and told me it looked okay.
I read that some Gigabyte motherboards have problem reading temp correctly, but if the computer freeze up after 1h of Crysis Warhead I guess it's because the heat is real...
Now I'm planning to go to his place and see what I can find out, but maybe someone has an idea?
I was planning to bring along my C2D Intel stock fan and try it out, but will it be okay with a Quad core?
I was also planning on bringing my Arctic Cooling MX-2 and see if that would help.
I downloaded Speedfan, cpu-z, RealTemp (tho he already has it) and prime95.
So any opinions on what I should try or check?
Thanks a lot for any ideas,
Here's his spec:
HSF: Zalman 9700NT,
