Tom's Hardware > Forum > Graphic & Displays > Nvidia > GPU or nforce problem ?
Forum Graphic & Displays : Nvidia - GPU or nforce problem ?
OK ... i just installed my brand new swiftech WC. (APEX ultra)
Putting everyting back in place with Distilled water and PT nuke. CARREFULLY filling it. Tilting till no more air. Just one LIL drop followed from the top off my case to the bottom, and one LIL drop on the back of the GPU but wipped it as soon as i saw it. I had removed my Nforce Cooler cause its kinda hot when i game. so i took it off, cleaned it and back on whit new Thermal paste.
Waited about 2hrs before turing it back ON and DAHHHHH ... Windows show up and boom lotta weird colored pixel... i can see that its my windows .. but whit tonns of weird color pixel with some alignement.
After restarting, i took a lok at the bios, NB v was 2.85 v ???? WTF ! its supposed to be 1.5 no ? took everything to normal, redone my OC to 3.6ghz, started again and finally windows run, but NO games ... even trying to use Nvidia monitor mess the whole thing up. Weird colored pixel and now CPU restart after 10 sec when this happen.
Windows run smooth ... 1650x1080 ..... :(
its similar to this.
http://www.playtool.com/pages/artifacts/screen0032fh.jpg
cant run ANY games ... i installed an OLD 7600GS that worked correctly if we can say that ...
P5N32e sli +
E6850
9800GTX+ SC
2x2gb G-skil Pi-black
600W TT toughpower.
XP64 pro
THX alot guyz !
Message edited by boulard83 on 01-24-2009 at 01:47:22 AM
------------------------------ __________________________Le Québécois_________________________
WCed Q9550 EO + P5Q @ 3.825ghz / HTPC - E5200 + P5Q @ 3.3ghz
BFG GTX285 OC2 + PC P&C 750w . / HIS HD4850 with Sharp 42" 1080p
Sponsored Links
well ... :(
Just redonne my OC, resetted everything to be SURE theres nothing somewhere in the bios messed up. 3.6 ghz ... runs fine ! Have a 80mm fans splashing to the NB, temp are good.
But STILL this anoying Color Pixel freeze :'( as soon as i start a game or even opening nView... i can inspect mobo-ram-cpu but if i click the GPU button ... COLOR PIXEL like the pix above all over the screen. :'(
GPU temp is fine ... a dead GPU ?
Reply to boulard83
...so the 7600GS works fine? if so, then i'm going to have to say you fried your card.
Reply to V3NOM
IM currently listenning video (youtube) .. windows .. etc everytings run ! but not the games .. the cards messs only with games ?!?!
and application that need acces direct to the card ... thats what making think about nforce ?
Message edited by boulard83 on 01-24-2009 at 03:24:25 AM
Reply to boulard83
Is your vid card OCed?
Mine looks like that when I turn the memory clock up to high.
Reply to pat mcgroin
no, its an SC version, running stock ... i already OCed it, but its running stock for a month.
Reply to boulard83
OK. the 7600gs just ran TF2 for about 10-15 min without a fail .. :( i think my 9800GTX+ is DEAD !
Ill go to futurshop tomorow to exchange the card. i still have the bill and have the card for less than a year. I think they could change it ;)
Reply to boulard83
hmm, my dads FX 5200 just died. lolz. back to onboard video.
DX problem? drivers?
Reply to V3NOM
i gived my FX5200 to a friend ;)
Your problem can be anything else, your sure its the GPU ?
Reply to boulard83
There are 1190 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
