Unfortunately I need to replace the MB on my HTPC. I originally built this in late ‘05, its main purpose was to store, and play music. I had available to me an ATI AWI 128Mb card so I used it as well.
ORIGNAL BUILD HIGHLIGHTS:
Silverstone Case
ASUS K8V SE Deluxe MB
AMD Athlon 64 3000+
ATI AWI 128mb video card
1GB PC3200 DDR 400MHZ
Even though it wasn’t a primary use, I never had much luck with the ATI AWI software when it came to recording TV. I recently started watching more AVI movies/TV shows using the HTPC. I have it connected to my rear-projection TV via s-video (TV is vintage ’98) so that is the best connection I can use. It is connected to my receiver via digital coax, I don’t have an open optical audio available.
The goals of this upgrade, beyond repairing the failing MB, would be to be able to record TV successfully, especially set up timer based recordings. Hopefully improve the playback of the AVI movies/tv shows. Not shell out a fortune!
New Build Changes:
Asus M2R32-MVP ATI Socket AM2 ATX Motherboard
AMD Athlon X2 7750 Black Edition Processor
OCZ SLI-Ready Edition Dual Channel 2048MB PC6400 DDR2 800MHz Memory
Sapphire Radeon HD 4670 - 512MB DDR3, PCI Express 2.0
Hauppauge WinTV-HVR-1800 | Hybrid Video Recorder
I do zero gaming, and this system ONLY stores and plays video, & music. I’ll be using WinXP Pro ( don’t care for Vista), and I don’t have XP 64Bit
Please provide any inputs as to the new components as you see fit, thanks!
Silverstone Case
AMD Athlon 64 3000+
New Build Changes:
