Most ECS boards are poor overclockers because of BIOS limitations. And the G41 is a budget chipset.
Go into the BIOS and look to see if you can change the FSB frequency, have some control over voltages, and can modify the voltages.
If you can do all of the above, you have a chance to overclock.
