Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > LCD TV and PC Monitor difference?
If i wanted to run a computer using a 26" LCD TV whats the difference from running it off say a 26" monitor? i just thinking i have a spare TV and cant be bothered to buy a new monitor if theres little difference... i think id use a HDMI off say a GTX260...
------------------------------ If you're falling off a cliff you might as well try to fly, you don't have much to lose...
BUILDING!!~ i7 920/GIGABYTE GA-EX58-UD5/3GB TripChan DDR3/Sony DVD-DL writer/ HDD500GB/HD4870 1GB/A+ Case/ANTEC500Earthwatts
Sponsored Links
come on seriously no answers?
Reply to OmegaStalker
Usually resolution, it used to be that monitors were of far superior quality in all areas but now i ain't sure.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
Personally, I rather have the 26" monitor myself. The average 26" LCD TV will only run at 1366X768 resolution versus the 1920X1200 resolution of the 26" monitor. Far as which monitor, I would get the Samsung 2693HM myself because I do a lot with Word, and I love the pivot feature.
Reply to runswindows95
- 0 +
A 26" monitor will usually have a 1920 x 1200 resolution. A very common one for games.
If the lcd tv has 1080P the resolution will be 1920x1080. Some games or displays will look strange.
If it is 720p, then the resolution will be even less.
Reply to geofelt
- 1 +
I do believe that resolution is still the key. If it were 1080p, it would be the same, I believe, but if it's 720, you won't have the same quality.
PS - to the OP - you wrote a second message when people hadn't responded within approximately 1/2 hour - be patient. Sometimes people read and don't have any knowledge of the issue. We are not all permanently logged on to help and get to it when we can.
Reply to huron
Dont forget refresh rate. With a 26inch monitor, you has the choice of running at a lower resolution of 1680x1050 and set at higher refresh rate of greater than 60hz. On a older LCD TV, max is 60hz regardless of resolution.
Running fast motion, a 60hz refresh rate is noticeable. That why newer big LCD TV are offering 120hz. If you dont mind playing at 1080p, a TV with refresh of 120hz is the cheaper ways to go.
Reply to jivdis1x
- 0 +
A refresh rate of 120hz is somewhat of a marketing ploy. Most lcd's have a rate of 60hz.
The source for a film may be as low as 24, and the tv may be 30. It takes a very good vga card to deliver more than 60fps, particularly with eye candy.
The tv or lcd can not display action any faster than the frames that are delivered to it.
Analog monitors are different. They need to be refreshed at 85hz to avoid flicker because, unlike lcd's, the frames need to be redrawn every cycle.
Reply to geofelt
Well, a 26" LCD TV is going to have less resolution than a good 26" LCD Monitor. If you can't really tell the difference then it may be better for you as your GPU won't have to work as hard :). As far as the visual quailty it's going to depend on the maker. If it's a recent Samsung then I would just use that and not even think about getting another monitor. Well really so long as it's anything other than an older Visio or some chepo brand you should be fine using it as a monitor :).
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
Refresh rate is not noticable as it does not exist, due to the fact that LCD's have two "refresh rates" it is best to know the difference.
How many signals per second the monitor can handle and how many times the Liquid crystals can change state are two different things.
I am not sure how it is now with response times but it used to be that a monitor with about a 8ms claimed response time could go over double that in reality.
You need roughly 16/17ms response time in theory to acheive 60fps.
To acheive 120fps on an lcd you would need a constant or mimimum response time of roughly 8ms. Whether that can be done i do not know but the faster and big change of state that is required the less amount of fps you will see.
Of course, i don't pay too much attention and others will be able to tell you if monitors nowadays can manage minimum response time of 8 or 16ms.
so basically if its a good TV use that if not buy a monitor?
- 0 +
I would say buy a monitor unless you need a screen size > 30"
Reply to geofelt
I dont know about differences but I run my comp w/ a 26" LCD Toshiba 720p. Absolutely love it. AFAIK the only difference is the Monitor probably can do higher resolution and the TV has a tuner in it.
Reply to jaredtrobinson
i have been looking for a 32" lcd monitor for a while now, but their pretty expensive. but checking around, i found that 32" lcd tv's are cheaper.
Reply to jbaeza1788
If your looking to play games and have them look there best then a Monitor is the way to go. As said higher resolution and they are designed to run with a PC.
Some TV sets, probably most by now have a PC mode but its not the same.
The refresh rate thing is slightly confusing but basically as strangestranger has said the response times to do these refresh rates are easily available. The math of 8ms comes out at a theoretical refresh rate of 125Hz.
This doesnt happen of course as there are limitations such a the DVI cable which i believe (correct me if I'm wrong) can only give around 80-85Hz, and is usually limited to 60 anyway. VGA is usually not as restricted but still not up to the theoretical 125Hz.
I'm not 100% up to date with it but i guess its the HDMI that lets the TV sets go up to these higher refresh rates.
Also remember that the people who make TVs and Monitors lie. Often quoting Grey-White-Grey times instead of Black-White-Black times. Why they can get away with it i don't know but they do.
The only guaranteed way to get what you want and like is to go to a shop and see for yourself.
Mactronix
Reply to mactronix
then check this
SONY BRAVIA KDL-40ZX1 LCD
it is 8ms reflesh rate
it is 1080p (full HD) 1920x1080
it is 100hz, higher than your 60hz monitors
it is 10bit (higher than your 8bit monitors)
5W+5W+10W(Woofer): with SS-TBL700 10W+10W: with SS-WAL700
able to display 576i, 480p, 576p, 1080i, 720p, 1080p, 24p input (not only 1080p)
4x HDMI input, picture in picture display, RCA inputs and old d-sub
and hundred of non very important pluses.
it is 40" or more, not 26" or less like monitors.
it is 1k euros, which is not very expensive for this features.
Reply to aslanyurek
There are 646 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
