I am building the system listed below. I was wondering if anyone had any suggestions on how I should connect and configure the fans (3 large - 1 small - not including CPU and PS fans). Any help would be appreciated.
I bought the HAF 932 last August. The case comes with the stock fans already installed and pre-configured for you. No need to change anything. Ventilation, airflow, and cooling are excellent.
I plug it to my PSU, i don't want the cables hanging in the middle of my casing, the cable some times is not long enough, if i connect to my PSU i can hide it easily lol
My motherboard came with 4 fan connections. I used two of them for the two 120mm fans that are attached to my tower style cpu heatsink. I could have connected two of the case fans to the motherboard but decided to connect all four case fans to my power supply. I ran the fan cables behind the motherboard tray and used a 4 pin molex connector also behind the motherboard tray. It looks neater.
