smithinator said:
I currently have a Sound Blaster Live! card that came with my Dell back in 2003, but want to upgrade for better sound with the Klipsch 2.1. 90% music/movies, 10% gaming(if that). I just want to simply plug the speaker in just like now and that's it, no other uses like stereo out or anything. Just computer and speakers. Cards I've researched: Syba Sound Card, SB X-fi xtremegamer, Auzentech X-fi Prelude, Asus Xonar, Omega Striker. Any suggestions?
EDIT: I forgot to mention I am running Windows XP with just PCI.
Smithinator, I have been using X-Fi for 3 years now and can only recommend this card, especially for gaming. I am using one with the front bay, but there is a cheaper version, that was mentioned here - called X-Fi Xtreme Gamer. It sounds as good and can be connected to the front jacks on the PC case.
I am kind of careful when people say product A "sucks" while B is a must-have for everyone (and their mother). Especially if we talk about well-established companies. Use your all judgement... Let me fill you in with some essential information.
Almost all non-Creative cards use C-media chips with more or less customized C-Media driver while Creative cards use E-mu chips with Creative own driver.
So, what's the deal?
1.
C-media chips were developed primarily for onboard audio and Xonar or Omega sound cards are based on the same chips that can be found on any of the current motherboards (ALC889 and similar). Arguably the more expensive sound cards use higher quality components (DAC, opamps) and if you have very good speakers or very good cans you will be able to hear the difference.
2.
E-mu chips used for X-Fi were developed exclusively for Creative sound cards. These cards are
capable of processing audio in hardware for higher accuracy and lower CPU usage. CPU usage is less of a factor now, although, if you are still on XP it might still benefit you. Either way - the audio, and primarily the gaming audio, is rendered in hardware with Creative cards, unlike with onboard audio and some other sound cards.
3.
EAX. X-Fi sound cards support all revisions of EAX, i.e. I think up to version 5... Other sound cards support lower revisions and non-Creative non-X-Fi cards only support versions 1 and 2 (a standard from mid 90's) EAX was developed by Creative and they made version 1 and 2 public but kept rights for upper versions to themselves only. This decision has been looked down by many users and, obviously, the competitors. After 10 years Asus released the Xonar card with a driver that tricks games into recognizing it as EAX 3 or 4 capable hardware. EAX calls (from the game) are accepted by Xonar and interpreted according to Asus algorithm which mimicks Creative patented EAX 3 and 4. It is more or less an attempt to reverse-engineer EAX, quite impressive - but not 100% accurate. There were several reports of sounds being messed up on Xonar cards. Fortunately new games use OpenAL instead which is less of an issue for any hardware that supports it.
4.
Vista and nForce. Microsoft redesigned audio processing in Vista. Creative were slow to come up with drivers that would work for all users on all motherboards in all configurations. I had no issues on my non high-end rig but people with new motherboards (notably nForce4 and then 5 ), plenty of RAM and Windows Vista - run into issues. After way too long these issues have been sorted out and X-Fi sound cards are a safe buy for Vista. Meanwhile Creative learned their lesson and was among first to release a beta driver for Windows 7. Past difficulties with Vista and/or nForce chipsets were widely known and helped companies like Asus to establish their new brand for sound cards - Xonar.
5.
Most reviews that I read conclude that X-Fi (E-Mu chip, remember?) sound cards are better suited for gaming while Xonar or Omega cards (C-Media) chip have an edge for music listening. Either product will probably deliver more than satisfactory results in both areas though. As for issues - currently there are compatibility issues with 7 series nVidia boards - i read about them in connection with Xonar D2X cards - but somehow I am sure that is not the only sound card affected
Anyway - if you really have an original Live sound card from the 90's give it a good burial (or ebay it - there are weirdos who'll buy!). Whatever card you decide to buy I am sure you will note the improvement over your old Sound Blaster Live.
Hope this helps,
Ben
