Hi guys,
I just brought this SSD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227550&cm_re=OCZ_vertex_2-_-20-227-550-_-Product
-WAs wondering.. is there a program or some kind of tools I can use to test its performance.. if it is indeed at least reading: up to 285MB/s and writing: up to 275MB/s
This is my first SSD and I am very newbie ..and also ..I thought all you needed was just pug in the SSD to either SATA II or SATA III and it should automatically detects and able to run at the manfactured stated speeds...........
BUT..
This guy from the review saying something about have to "enable" in Bios "AHCI" or update firmwire to all allow the SSD to read at its max..:
Words of advice: To everyone considering this (or any OCZ) drive, do you know what AHCI mode is? If you do not, be ready for several hours of frustration, research, and tweaking of your OS. If you do not configure the computer to AHCI mode before installing Windows, you will see decreased performance (which will be less than half the max performace speed listed on the box). Also, you won't be able to upgrade the Firmware of the drive.
Look in your BIOS for the AHCI configuration choice. If you happen to have a latop, like myself, where there IS no setting like that, check and see if there's a RAID enable/disable choice. I could start in AHCI mode if I had the RAID entry enabled.
Other Thoughts: If you had no previous knowledge of SSD's and you bought one, the drive would still work, but you would not get the performance listed by the manufactorer. You would need to go to the company's website, check for any updates to the drives, and read they're forums for other peoples advice and support.
That said, the "manual" that comes with the drive has no mention that the drive performs best in AHCI mode or that Firmware drivers are available on the company website. Even a small paragraph listed somewhere in/on the box with that information would have saved me (and countless others) several hours of grief.
Any suggestion or comments please..Thanks
BUT..
