I currently have a corsair h50 water cooler. Recently my motherboard took a dump and I had to send it out for an RMA, so of course I had to take everything off the motherboard. In doing so I took the cooler off with its preinstalled thermal paste type like solid. Before I sent it in I could run prime 95 and get max temps of around 51/52 degrees celsius and idle around 36. When I reinstalled I used arctic silver 5 thermal compound, now im idling at around 40 degrees celsius and prime 95 will get my cpu to about 60 and ill have to shut it off, I just did it yesterday and I know arctic has a break in period and I was wondering if it is due to that. I used the middle dot method and followed their instructions down to the tee. I used isopropyl alcohol with a q-tip and even the coffee filter. The only two things that I could think of is maybe my pea sized amount was too much little, but it really was a pea sized amount and in order to get the pump on the bracket it does require some about a 20 degree clockwise turn dont know if that has to do something with it?
